No spark on my 280z-T conversion ('82 zxt doner)
Hey guys. I have been working on my swap for a while and last night I got the car to fire up. Perfect idle and all, but the wires were just in a temperorary fix. Today I went ahead and hooked them up cleaner and now I am not getting any spark. I am working with a buddy of mine who knows the Z pretty much inside and out as well as having done a few turbo swaps.
Let me start off by saying that none of the wires were changed in the way they were setup, just hooked up better with clips instead of being set in place. We are in the area of trying to see why we are getting no signal to the coil to (turn on?) from the ECU? or is it the other way around? It is a yellow wire with a white stripe connected to the #5 pin on the big clip into the ECU.
We are dead in the water. Car started up first try last night and here today we get no spark. PLEASE HELP!
  • 4 weeks later...
Mine turned out to be the crank angle sensor in the distributor. You can test it by probing the ECU connector, pins 8 and 17 (I think, check your FSM) should have a ~4v square pulsing wave when the engine is cranked. One of them should pulse quickly, every 1 degree of rotation, and the other should pulse slower, every 120 degrees of rotation. If you can get ahold of an oscilloscope it will be easier to diagnose.
