DRZ man Posted April 6, 2009 Share Posted April 6, 2009 Hi all, I finally got megasquirt install in my car, but Im having some problems loading the firmware, this is what I have try all ports, different wires as a boot loader, different software from different sites. Im using windows vista with DIYautotune USB and adapter, the board is green 2.2. The set up is l28et, holset turbo with stock injectors( just to get it started), 420cc mercedez injectors low imp. I bought the complete kit from a member brand new and the instructions for wiring say v3.0 for some reason, so I wire everything like the instructions say, please help me figure out this problem, I know Im pretty close Im just not there yet, thanks. Quote Link to comment Share on other sites More sharing options...
softopz Posted April 6, 2009 Share Posted April 6, 2009 Is megasquirt lit up? It is has to have power from 12v Is the usb adaptor configured right I remember I had to do something like set the buffer . From the device manager just after installing the drivers properly. There is a program there to test if you have communication. also there is a great page on communication issues. its really informative its on megatune.info in troubleshooting. Also you need to say what step your exactly having trouble with are you using the proper boot loader program there is one for ms 1 and ms 2 I believe. If your sayin the board saying 2.2 and your using wiring for 3.0 you need to check if thats ok before even loading firmware. Quote Link to comment Share on other sites More sharing options...
Robert Posted April 6, 2009 Share Posted April 6, 2009 You need to follow the steps in the manual for configuring the COM port to the correct baud rate depending on MSI or MSII is installed.. Also use the settings for connection problems with low performance. And add some details in your next post Quote Link to comment Share on other sites More sharing options...
DRZ man Posted April 6, 2009 Author Share Posted April 6, 2009 Megasquirt has 12v, both of my injectors lights blink on the megasquirt ecu, I try using 3 different programs to load the firmware and it didnt work, I try portcheck and there is not connections, "s" is all i get from that program. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 6, 2009 Share Posted April 6, 2009 Please post both a screen shot of the port check program and the errors you are getting trying to load the code. Quote Link to comment Share on other sites More sharing options...
DRZ man Posted April 10, 2009 Author Share Posted April 10, 2009 Quote Link to comment Share on other sites More sharing options...
Noddle Posted April 10, 2009 Share Posted April 10, 2009 DRZ man said: [attach]13264[/attach] [attach]13265[/attach] Looking at the 2 pictures, the top one (checker), says Com3 is ok, the bottom picture (loader), says Com1 is invalid, looks like you need to tell the loader to use Com3 and not Com1 Nigel Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 10, 2009 Share Posted April 10, 2009 Com 3 doesn't look like it is a real port - the "S" response usually indicates it's some sort of diagnostic port that echos back every character sent. Check in the Device Manager and see if you can find the USB adapter. You may need to reload its driver. Quote Link to comment Share on other sites More sharing options...
