Guest Anonymous Posted April 12, 2000 Share Posted April 12, 2000 I've got a Z running an all-alloy 4.4l V8 making high-200s h.p. figures. I'm having some overheating problems, even at say 60 m.p.h. The car is running a modified 260Z radiator, the core being three row instead of two. All other dimensions are standard. I'm pretty sure everything's OK (thermostat, water pump, etc.). What radiators are people out there running that work OK? FYI, I'm in Australia so if you're referring to a non-Australian model, can you give a generic description, such as dimensions, no. of rows, alloy core/tanks, etc. Thanks!! Quote Link to comment Share on other sites More sharing options...
Mikelly Posted April 12, 2000 Share Posted April 12, 2000 I have a Griffen aluminum racing radiator and I also had problems until I got a fan shroud for it. I'm using a Hayden Semi-Flex 17inch fan and I had to get the shroud so I could mpull more air through the radiator... The fan blades are over 5 inches form the radiator surface, and that is just too far back from the radiator to pull any significant air through it. If you are running a mechanical fan, get yourself a shroud and this problem will go away... Others will speak on the electrical fan issue... Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted April 12, 2000 Share Posted April 12, 2000 Zedskid,I just wanted to tell you that I thought you did a nice job with your car.I realy like the split bumper on the front.The eng.compartment is also done very neat.I think I saw it on z-driver? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 12, 2000 Share Posted April 12, 2000 Thanks Ron, yep that's the one. On the split bumper, I just don't like the look of the standard unit; it looks like the car's wearing teeth braces...... These came out OK but not quite what I wanted. Also, if you're ever thinking of getting electroplating done in Australia I can tell you someone NOT to use.... Quote Link to comment Share on other sites More sharing options...
Guest mattrp Posted April 13, 2000 Share Posted April 13, 2000 I also have a 260z radiator on my v8. I was noticing a little difficulty keeping the temps at the thermostat level when I had the felx engine driven fan with no shroud. Since then I have modified an electric fan from a ford taurus and leave it running at all times. I can drag hard, then stop indefinitely with no problem. I went autocrossing last weekend, and spent three hours during one minute runs followed by 20 minutes of idleing, no problem. Matt 72 500Z Quote Link to comment Share on other sites More sharing options...
MYRON Posted April 13, 2000 Share Posted April 13, 2000 I must be the only lucky one. I am using a stock radiator with a 475+ hp motor and I cruized town & raced some people and ran through a full tank of gas and i never jumped above 180 degrees! I am using a weiand water pump and a 160 thermostat... The vehicle does NOT have a/c to restrict flow through the radiator... I am also using a 16" electric fan.... Quote Link to comment Share on other sites More sharing options...
MYRON Posted April 13, 2000 Share Posted April 13, 2000 Zedskid, Where exactly can one see a picture of your car? Quote Link to comment Share on other sites More sharing options...
Sumo Posted April 13, 2000 Share Posted April 13, 2000 quote: Originally posted by MYRON: Zedskid, Where exactly can one see a picture of your car? Hey Myron check out his profile, he left an address so you can check out his car. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 13, 2000 Share Posted April 13, 2000 Yup this is true - there's even some recent updates there on my last (not so successful...) track outing. But to save clicks, it's www.ozemail.com.au/~zedskid for them that's curious. Quote Link to comment Share on other sites More sharing options...
