Guest Anonymous Posted April 29, 2000 Share Posted April 29, 2000 For those of you that have relocated the battery to the back of the car, where are you putting it? How are you securing it? Is there a lot of cutting, drilling and welding involved? What is the route of the battery cables? I appreciate any info. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted April 29, 2000 Share Posted April 29, 2000 Mine is in the back right, behind the rear fenderwell. It is secured with 3/8th inch threadall, nylon impregnated nuts, and fender washers. I use 1/0 wire all the way up, and bulkhead mounts on the rear deck to run the battery cables to. My kit was a Summit kit, but I upgraded the wired and made sure to fabricate a bracket to bolt the box in place. I welded nothing. Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Owen Posted April 30, 2000 Share Posted April 30, 2000 Mine is in the same location. I ran the 1/0 gauge batt cable behind the R fender, where the stock wiring for the interior lite, rear defroster, etc. ran. Then thru the door rails to the front. I used a Moroso box kit, two 3/8 inch bolts thru the floor secure the box. Cables used were Taylor. I welded a bolt to the chassis as a ground post. Owen ------------------ http://www.homestead.com/s30z/index.html Quote Link to comment Share on other sites More sharing options...
