Will the front AZC 4 piston Wilwood brake kit fit 15x7 +0?
they fit my 15x7's. I have no idea what the offset is, but I would assume it would be whatever is stock (they came with the car). I have 2 different rims of the same size that do fit, but both need spacers, and one set that doesn't. The two sets that fit are alloy and the one that doesn't is welded steel. I have the 6 piston fronts and 4 piston rears. Both have issues with the face of the wheel being too close, not the inside of the rim. The rear just needed a 1/8" spacer, the front needed 1/2" inch.
I would assume the 4 piston fronts are somewhere in between. I really think the shape of the inside face of the wheel has more to do with the rims fitting than anything else.
Not all 15" wheels will clear those brakes. I tried a set of Sportmax 15x8 +0 wheels and they didn't clear the calipers. On my P1 Racing wheels, they clear, but they have tons of room for brakes. My only advice is to check wheel fitment before mounting tires in case you need to return them.
Here are my 15x8 +10 "P1 Racing" wheels.
http://www.zccne.org/simple_gallery/albums/Members/pete/DSC00007.jpg
