Xnke Posted April 15, 2009 Share Posted April 15, 2009 Anyone here able to make good sense of this cam card? Essentially, this is the card for Delta Camshaft's 270/280 split duration cam. I have the straight 280 duration cam. For my purposes, I am to ignore the intake numbers on this card, and "reverse the exhaust numbers to get the intake". Anyone else able to help me read this card? Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted April 15, 2009 Share Posted April 15, 2009 http://forum.grumpysperformance.com/viewtopic.php?f=52&t=1477 http://www.crower.com/misc/valve_timing_chart.html Quote Link to comment Share on other sites More sharing options...
Xnke Posted April 16, 2009 Author Share Posted April 16, 2009 I appreciate the links Grumpy, but they are basically the same as what I have already. A lot of numbers, but no real meaning. I'd like to try to put the numbers to work, meaning I need to know what numbers are for show, and what numbers are for working. Quote Link to comment Share on other sites More sharing options...
Phred Posted April 18, 2009 Share Posted April 18, 2009 This is not a cam card as normally supplied by cam grinders. Cam Analyzer is computer program, used with a fixture that rotates a cam in a jig on a bench. Electronic sensors send the rotational, lobe, and lift info to the program which converts the info to data and lobe profile charts. All this info is of little use to an end user, but is very usefull to an engine builder who can use the data to compare cam profiles from one grind to another. The program allows onscreen overlays to quickly visualize and compare grinds, and make a decision as to which profile to use for a given engine. The chart you attached also has all the info that is normally supplied with a std. cam card. If you want to compare this cam to others, the specs you want to pick out of all this mess is: Lobe centerline Lobe lift or valve lift Duration See the cam timing sticky on how to degree your cam, and it will make more sense. FWIW This is just general info supplied by someone who has used this type of equipment. Quote Link to comment Share on other sites More sharing options...
