ASenna Posted April 19, 2009 Share Posted April 19, 2009 ...we meet again. Hi all, I recently acquired my 1975 280Z from another member here on HybridZ about a week ago. The car's in great running shape ( other than then fuel pump I'm replacing this week ), but I can't live without turn signals. I've searched and searched ( even through some old threads when I had the problem on my 76 ), but I can't find a good solution to this typical problem. Symptoms ( or clues I guess ): - All parking lights work, but when hazards engaged, front right does not blink ( ground? and if so, where would be the likely culprit? ) - No turn signals blink ever ( cleaned the switch, still nothing but I expected nothing ) - Both headlights and hi beams work like champs. Running on MSII and most of the wiring doesn't run through the fusebox, but should I check there? Could the hazard switch be another culprit? Ignition switch? Thanks in advance Quote Link to comment Share on other sites More sharing options...
slown280z Posted April 21, 2009 Share Posted April 21, 2009 It's almost, ALMOST always a ground issue. There's 2 grounds by the turnsignals in the front of the car. Also, these cars have a flasher for hazards, and one for turn signals. It could quite possibly be a bad flasher. Quote Link to comment Share on other sites More sharing options...
loy Posted April 21, 2009 Share Posted April 21, 2009 I would check the flasher and check the harness on the passenger side, the harness that has the hazard switch on. Quote Link to comment Share on other sites More sharing options...
pezair Posted August 6, 2009 Share Posted August 6, 2009 I have the same problem and i hate electrical stuff. I have a 1975 280z and i modified the taillights with dual round trailer lights on each side (same look as a corvette). I wired then as per the directions and everything seemed to work then soon after my turn signals failed. At the moment i have: Hazards that work (only without headlights on), Headlights work but i have the turn signal dash lights staying on whenever the headlights are on. All lights work in this condition. However i get no response anywhere when i try the turn signals, no flasher clicks no dash light, nothing. I changed out flasher units, cleaned contacts and took it to a mechanic who decided after 3 hours that it was the hazard switch. I have power coming through the green wire and flowing to the hazards but no power will flow through the blinker wires out of the hazard switch. Quote Link to comment Share on other sites More sharing options...
ArizonaZ Posted August 6, 2009 Share Posted August 6, 2009 I had the same problem, and tried everything to get my turn signals to work. Cleaning the hazard switch was all that it took for the signals to work again. Here is how I did it Take out hazard switch from console. Then take out the four screws in the back Then take out the little pivot piece Then I just sanded down all four contact pads with 600 grit sandpaper, cleaned it then put it back in. and now my turn signals work great Quote Link to comment Share on other sites More sharing options...
280znoob Posted November 28, 2009 Share Posted November 28, 2009 ArizonaZ said: I had the same problem, and tried everything to get my turn signals to work. Cleaning the hazard switch was all that it took for the signals to work again. Here is how I did it Take out hazard switch from console. Then take out the four screws in the back Then take out the little pivot piece Then I just sanded down all four contact pads with 600 grit sandpaper, cleaned it then put it back in. and now my turn signals work great i tried this and while i did learn a little(great advice) I still cant get my signals to work off of the tree.would it be possible to solder a toggle to left contacts for left signal and right contacts for right signal,and just operate them as i need them or flick them both for hazards?> Maybe put lighted toggles so i could have the visual assurance as well? Quote Link to comment Share on other sites More sharing options...
blackice280zxt Posted November 28, 2009 Share Posted November 28, 2009 280znoob said: i tried this and while i did learn a little(great advice) I still cant get my signals to work off of the tree.would it be possible to solder a toggle to left contacts for left signal and right contacts for right signal,and just operate them as i need them or flick them both for hazards?> Maybe put lighted toggles so i could have the visual assurance as well? or you could fix it right..... Quote Link to comment Share on other sites More sharing options...
280znoob Posted November 28, 2009 Share Posted November 28, 2009 blackice280zxt said: or you could fix it right..... PO ratnested the wiring...much hope is lost. Quote Link to comment Share on other sites More sharing options...
turbeau Posted December 29, 2009 Share Posted December 29, 2009 i feel the pain, one works intermittenly. dash flashers work and sometimes click, but no outside turn signals. hazards can make all bulbs flash w/no problem. keep up the good fight! Quote Link to comment Share on other sites More sharing options...
