#1 cylinder dead....
It has very little ticking in the exhaust, no milky coolant,no coolant off that I can tell.I did a wet compression test this morning and the compression jumped to 55 psi a couple of times so im guessing bad rings. This will be the 3rd time I have had this head off and yes I have replaced the head gasket each time and the head bolts the last time.
I will take the head off and see I hope its that but if I put oil in the cylinder and did a compression test and it pushed 55-75 psi unless it pushing the oil into the head and seal it?? I realy thing its rings but I hope maybe something like that is wrong I would be realy happy.
