menzzer37 Posted May 4, 2009 Share Posted May 4, 2009 I just mounted a 15 gallon aluminum RCI fuel cell in the rear of my 76 280, but I'm a little lost as to wiring the sender. It has a 90 ohm gm style with the center nut terminal and a side spade. Does anyone know which of the 3 wires from the original harness to go what? I searched but with no luck. Thanks Quote Link to comment Share on other sites More sharing options...
menzzer37 Posted May 5, 2009 Author Share Posted May 5, 2009 anyone? Quote Link to comment Share on other sites More sharing options...
nick77 Posted May 5, 2009 Share Posted May 5, 2009 on your new aftermarket gauge or gm gauge it will have 3 wires coming out ground(for the gauge), 12v switched power for the gauge, last one is for the sending unit center terminal(with the nut), and the spade terminal on the sending unit is the sending units ground Quote Link to comment Share on other sites More sharing options...
menzzer37 Posted May 5, 2009 Author Share Posted May 5, 2009 That's a little confusing. I have the stock fuel gauge, so which wires to go what on the fuel cell? Quote Link to comment Share on other sites More sharing options...
bobbyc Posted May 6, 2009 Share Posted May 6, 2009 it wont read correctly with the stock gauge...the gm is 0-90ohms...the stock is different. Quote Link to comment Share on other sites More sharing options...
menzzer37 Posted May 6, 2009 Author Share Posted May 6, 2009 Do you know what the stock range is? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 6, 2009 Share Posted May 6, 2009 This post may help: http://forums.hybridz.org/showthread.php?t=127605 Quote Link to comment Share on other sites More sharing options...
