theghosttanker Posted May 9, 2009 Share Posted May 9, 2009 I'm putting together an l-28 (f-54 block) to put in my 73. I went to install the oil pan and the pickup tube and screen won't let it come back far enough on the motor. Now I'm kickin myself because I KNEW that there were fitment issues with oilpans when you do a swap, but I just forgot. And while I was forgetting, I threw away two oil pans and one pickup tube. I have two (identical) pickup tubes and one oil pan left, and I don't remember what motor the pan or tubes came off. Which pan and tube do I need to do the swap? Are all the tubes identical but the pans different, or what? I have another l-24 motor but it's in a car and I don't want to pull it right now. Quote Link to comment Share on other sites More sharing options...
evildky Posted May 10, 2009 Share Posted May 10, 2009 if memory serves there are 2 different pickups but both shoudl be compatible with both versions of stock oil pans (mid and rear sump) but I believe only the 280zx style pickup is compatible with the azc oil pan Quote Link to comment Share on other sites More sharing options...
