Rear Brake Conversion
The combo listed above using the correct Maxima brackets WILL fit under most 14' wheels, including the slotted mags and stock wheels. Most people have clearance issue with 14' wheels when they use the 240SX rear brake swap. I used to have a set of 14' Appliance slotted mags and they did not fit under the 240SX swap but would clear the 81 Maxima disc brake swap with no problem.
Hope this helps.
I currently have some 70's era aluminum slotted mags, but may go with the original steel wheels/caps. Thanks, Kevin
