71 240Z Head questions
ciavola
I am reassembling my motor, all stock. I had the Head resurfaced. cam regrind. I thought I had read where you have to use a shim with the head gasket if you have had the head resurfaced?
Anyone have any info?
If your head has had (aggregate) more than .015" taken off of it, then yes, you need shims under the cam towers. MSA sells them in .015" increments (how convenient!). You don't need to do anything to the head gasket side. Some folks shave the head down a lot (.080") to boost compression ratio, and build up the cam towers with multiple shims. Keeps the timing chain taut and keeps cam timing far more stable due to less chain slop.
