jeffer949 Posted June 11, 2009 Share Posted June 11, 2009 So i got the boost control to work. I still need to mess with it more but i was getting a pretty steady 10psi with the duty targets set at 40 percent. I want to mess with the gain some to see if i can get it a little bit more stable. And of course i need to raise the duty up alot to get me back up to 20psi http://www.msextra.com/manuals/MS_Extra_Hardware_Manual.htm#boost the the circuit mod that you do on the board. http://www.diyautotune.com/catalog/ebc-electronic-boost-control-solenoid-kit-p-285.html This is the solenoid that im using from diy auto tune but i might try to use the solenoid that is built onto my HE351CW turbo. One thing that i did that im not sure if Prox. did when he tried it was i isolated the IRLZ44 from the case or what ever you have it mounted to. I wish i still had a camera so i could take some pictures and make a vid but it broke. So no dice. Quote Link to comment Share on other sites More sharing options...
softopz Posted June 11, 2009 Share Posted June 11, 2009 SICK! thats makes you the first on this forum. So it uses the GM valve>? how is it wired? So within megatune you put the desired amount of boost to run? Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted June 11, 2009 Author Share Posted June 11, 2009 No its not the gm valve its the one that diy autotune sells right now. And I guess i should of been more clear. Im running the boost control in open loop mode so it only goes off of the boost duty targets instead of the kpa targets. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted June 12, 2009 Share Posted June 12, 2009 The valve we're selling works very similar to the GM valve - it's just we haven't been able to find an affordable source for the GM valve as it's been discontinued. The settings for our solenoid will work with a GM valve except the GM valve needs a bit more duty cycle. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 12, 2009 Share Posted June 12, 2009 what do ya mean you isolated the IRLZ44 from the case? Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted June 12, 2009 Author Share Posted June 12, 2009 With a mica pad so it wasnt grounding out. The drain is the same as the mounting tab so if you have it straight mounted to the case which is grounded its just going to take the least path of resistance and go to ground instead of go through the valve. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 17, 2009 Share Posted June 17, 2009 hmm.. when i mounted the IRLZ44 on a nylon washer.. with a nylon bolt... the valve would stay OPEN and would not close... Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted June 17, 2009 Author Share Posted June 17, 2009 was the tab touching the case though?? Quote Link to comment Share on other sites More sharing options...
HB280ZT Posted November 15, 2009 Share Posted November 15, 2009 Hi Guys, Any more update on the MS boost controller?? Have you been able to get back to your target boost of 20psi yet, if so give us the information and pictures if you can. HB280ZT Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted November 20, 2009 Author Share Posted November 20, 2009 My car has been down for the past few months and had been driving it around for a few months with said blown motor so i wasnt tunning any. Its all doable its just going to take a lot of time to get it set correctly. One thing i noticed is i could get it to hit my boost targets in one gear and then if i did it in another gear it would either not hit them or would spike like crazy. Quote Link to comment Share on other sites More sharing options...
HB280ZT Posted November 21, 2009 Share Posted November 21, 2009 To bad about the car and the boost controller problems. I guess I am back to trying to figure out how to get this to work as I need something other then a manual boost controller to play with. Oh well there has to be away to just turn the boost controller on and off when you hit a set boost. Will keep you all posted if I figure out something. HB280ZT Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted November 22, 2009 Author Share Posted November 22, 2009 Picked up 2 turbo motors today. Hopefully they will get me back in the game pretty quick. Ill be back to messing with the boost controller soon hopefully. Quote Link to comment Share on other sites More sharing options...
softopz Posted November 22, 2009 Share Posted November 22, 2009 yah I havent seen too many ms "ebc" that actually works hb280zt here is what your looking for ! http://forums.hybridz.org/showthread.php?p=1073956 Iam getting one for sure. no way iam playing with ms for something like boost control or paying crazy for greedy ebc Quote Link to comment Share on other sites More sharing options...
