kcambron Posted June 15, 2009 Share Posted June 15, 2009 My computer crashed and I lost most of my links, I'm looking for the essembly order for the rear stub axle. I think I'm straight except for the copper washer. Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
johnc Posted June 15, 2009 Share Posted June 15, 2009 1. Press the outer bearing onto the side shaft. 2. Press or lightly hammer the side axle with the outer bearing in the hub. 3. Drop the distance piece (spacer) in place. 4. Place and light tap (with a brass drift) the inner bearing in place. 5. Bolt on the companion flange and torque to 195 ft. lb. 6. Measure shaft end place and turning torque. 7. If in spec, remove the companion flange, install the seal, bolt on the companion flange and torque to spec. 8. If too much end play, remove the companion flange and add in the the copper washer. Go back to 5. If still too much end place, increase torque to 200 ft. lb. and go to 7. 9. If too much turning torque, reduce the torque number to 185 ft. lb. Go to 6. Quote Link to comment Share on other sites More sharing options...
kcambron Posted June 15, 2009 Author Share Posted June 15, 2009 Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
