shadesh Posted June 16, 2009 Share Posted June 16, 2009 I have a L24 engine and wanted to know if I can install the flywheel and clutch from a L28 engine? I bought the l24 without the flywheel and just not sure if I can swap... Any feedback will be really appreciated. Thanks. Shadesh Quote Link to comment Share on other sites More sharing options...
Phlebmaster Posted June 17, 2009 Share Posted June 17, 2009 I swapped my L24 flywheel and clutch onto my L26. Works just fine. I don't think the L6 motors are like the L4's. (The L16 and L18 flywheel/clutch (200mm 5 bolt crank) can interchange, but the L20b has a larger (225mm flywheel 6 bolt crank.) I would expect the L24 stuff to work with the L28 and visa versa, can you get pictures or test fit?? Quote Link to comment Share on other sites More sharing options...
shadesh Posted June 18, 2009 Author Share Posted June 18, 2009 I swapped my L24 flywheel and clutch onto my L26. Works just fine. I don't think the L6 motors are like the L4's. (The L16 and L18 flywheel/clutch (200mm 5 bolt crank) can interchange, but the L20b has a larger (225mm flywheel 6 bolt crank.) I would expect the L24 stuff to work with the L28 and visa versa, can you get pictures or test fit?? Thanks Phlebmaster.. I will take some pics soon and post. Can anyone else chime in as well.. just so that we are certain...Please. Thanks. Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted June 18, 2009 Share Posted June 18, 2009 Yes, they can be swapped no problem. Quote Link to comment Share on other sites More sharing options...
shadesh Posted June 18, 2009 Author Share Posted June 18, 2009 Yes, they can be swapped no problem. Thank You Sir.. Quote Link to comment Share on other sites More sharing options...
Phlebmaster Posted June 18, 2009 Share Posted June 18, 2009 Good to know so when I pick up an L28 I know I can use the parts off of my L26. Quote Link to comment Share on other sites More sharing options...
