Clutch Pedal blocker question
streeteg
So, my clutch is on the brink of being fully disengaged when pressed in--- and it has to do with the fact that the stock clutch pedal regulator (the welded piece of metal to the firewall that stops the clutch pedal from being pressed all the way) is in the way. Before I cut this thing off--- Can a clutch be pushed in too far? Should I trim it down and reweld or can I cut it all the way?
TIA
-E
You need to increase the length of the rod that is going from the clutch pedal to the master cylinder. Its threaded into the back of your pedal and held tight with a nut... Loosen the nut and back out the rod until you have proper engagement.
