LS1 fuel feed: cell or tank?
Sort of R-rated explanation of the Cheesepocket thing, I'll have to pass.
So the lower outlet is the output from the pump. That goes to the Corvette filter/regulator input. That filter/regulator then sends whatever fuel is demanded out it's outlet, and the balance is sent back into the tank, via the other outlet labelled return.
A Vette factory pump would have a similar configuration, though possibly more pipes coming out of it to handle the venting of the gas fumes.
I chose this configuration to allow me to do an in-tank pump to reduce noise, and to allow me to run just one fuel line forward to the engine, since the filter/regulator sits back near the tank.
I got all my info on the Vette filter/regulator off this site. I should point out that I'm still putting this car together, but I don't have any reason to think this won't work. I'll get to test the fuel system soon, though.
