turbojohnny Posted July 4, 2009 Share Posted July 4, 2009 on my '77 280 i just replaced the head gasket, it's all back together but when i go to start it i'm not getting fuel to the fire. when i spray starter fluid into the intake it'll run. so i know i hae spark, and i know i have fuel pressure after the fuel filter because when i loosen the hose it'll squirt out. and info as to why i'm not getting fuel into the cylinder? do i need to bleed any air out of the fuel rail? Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 4, 2009 Author Share Posted July 4, 2009 okay so the fuel pressure regulator is not letting any fuel through. it must be stuck closed. on to the search button. Quote Link to comment Share on other sites More sharing options...
ktm Posted July 4, 2009 Share Posted July 4, 2009 If the FPR is not letting any fuel through, then your fuel pressure would be incredibly high. Sounds like you may be airlocking your lines (similar to vapor lock). I had this problem for a while on my car whenever I would have to drain the main fuel line and then try to start it. Try disconnecting the return line after the FPR and blowing through it. Read the paragraph at the very bottom. It mentions air locking. http://en.wikipedia.org/wiki/Vapor_lock Quote Link to comment Share on other sites More sharing options...
jc052685 Posted July 4, 2009 Share Posted July 4, 2009 Have you checked to make sure your injectors are even firing? Do you have injector pulse? What is the fuel pressure in the rail? What efi are you using? Factory fuel rail? Please fill us in on your car... Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 4, 2009 Author Share Posted July 4, 2009 it's all stock fuel injection, other than the bae turbo kit, i don't know if the injectors are pulsing, but i have no fuel after the regulator. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 4, 2009 Author Share Posted July 4, 2009 so reading that bit on wiki, if my engine is air locked i would need to prime my fuel lines? meaning filling them with fuel up to the outlets on the regulator, i've tried constantly turning over the motor to prime them but it hasn't seemed to work. i have my regulator sitting with some wd-40 in all of the inlets/outlets and the vacuum port on the bottom side of it just in case something is siezed. also i do have pretty high fuel pressure before the regulator, when i removed it the pressure shot the fuel all the way to the firewall i think there was probably a better way to relieve the pressure, but i wasn't too worried about it at the time. Quote Link to comment Share on other sites More sharing options...
jc052685 Posted July 5, 2009 Share Posted July 5, 2009 So, how do you know you have no fuel after the regulator? You need to use a noid light to check for injector pulse. What is the pressure before the regulator? dont tell us "its pretty high". So with the fule line comming from the fuel pump/filter disconected there is fuel FLOW comming out when you turn on the key? Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 5, 2009 Author Share Posted July 5, 2009 i can't tell you an exact psi, because i didn't measure it, it is substantial pressure, i have fuel all the way up to the regulator but nothing after the regulator. Quote Link to comment Share on other sites More sharing options...
jc052685 Posted July 5, 2009 Share Posted July 5, 2009 Well then you ned to verify your getting injector pulse. If you are then it sounds to my like too high of a fuel presure is causing too rich of a fuel mixture to fire. You should pull the spark plugs. I suspect they are drenched in fuel. Also if you have spent alot of time trying to start the motor you may have washed down the cylinder walls and may not have any compression left. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 5, 2009 Author Share Posted July 5, 2009 I'M NOT GETTING FUEL PAST THE REGULATOR! there is no fuel through the injectors, i have supply to the regulator, but the regulator is stuck closed. Quote Link to comment Share on other sites More sharing options...
jc052685 Posted July 5, 2009 Share Posted July 5, 2009 THEN YOU DID IT WRONG!!! The regulator goes after the fuel rail!! If the fuel is getting to the regulator then fuel IS getting to the injectors. On a factory setup. This tells me you connected the lines all wrong somehow......Oh, sounds like you have the fuel feed and return lines backwards. Switchem!! Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 5, 2009 Author Share Posted July 5, 2009 this would make sense! lol stupid me! thank you sir please forgive my ignorance! Quote Link to comment Share on other sites More sharing options...
jc052685 Posted July 5, 2009 Share Posted July 5, 2009 this would make sense!lol stupid me! thank you sir please forgive my ignorance! So have you acctually tried this AND it worked? Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 5, 2009 Author Share Posted July 5, 2009 first thing in the morning i will, it's too dark out to do anything on the car right now. i'll keep you posted though. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 5, 2009 Author Share Posted July 5, 2009 you were absolutely 100% dead on, i had the return and supply lines switched! thanks for the input! Quote Link to comment Share on other sites More sharing options...
jc052685 Posted July 5, 2009 Share Posted July 5, 2009 you were absolutely 100% dead on, i had the return and supply lines switched!thanks for the input! Haha, sweet! Sounds like its time for a celebratory burn out!! Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 5, 2009 Author Share Posted July 5, 2009 yes sir, i took it for a spin (first time i've driven the car since i bought it) i didn't do any burnouts, but my radiator exploded lol looks like i've got a little more work ahead of me. any recommendations on a good radiator? Quote Link to comment Share on other sites More sharing options...
jc052685 Posted July 6, 2009 Share Posted July 6, 2009 Well I have a radiator for a 280z in great condition I am willing to sell. All brass construction. PM me an offer. Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted July 6, 2009 Author Share Posted July 6, 2009 i ordered a new one from the local parts store, it showed up today, but was damaged during shipment, another one should be here tomorrow, hopefully undamaged. Quote Link to comment Share on other sites More sharing options...
ktm Posted July 7, 2009 Share Posted July 7, 2009 Sometimes it is the most obvious solution. Quote Link to comment Share on other sites More sharing options...
