injector pintle caps required?
bernie lomax
which injectors?
they are called pintle caps.
some injectors flow very high numbers with little degradation in spray-pattern when they're removed (subaru injectors of sorts)
some flow marginally worse due to pattern inconsistency and fuel droplets spewing out rather than spray.
thx for the response...the injectors are stock 78 L28E...I've rigged up a tester to spray into a glass jar...will remove pintle cap on one to see if stream squirt turns into conical spray...if spray is better shape w/ bare metal tip, then I'd go bareback but will have to make sure o-ring stays on...if this sounds ok or if I'm inviting trouble, pls let me know...thx for your time
