dhp123166 Posted July 18, 2009 Author Share Posted July 18, 2009 I'm not talking about breaking the law... Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted July 18, 2009 Share Posted July 18, 2009 dhp123166 said: I'll be looking forward to that swap, are you going to turbo it or get it to run on biodiesel? Turbo for sure (probably the same time I swap the engine in. the 280ZXT Manis bolt up with a little bit of dremel fun). Biodiesel should be fine anyway, but I won't be running it on WVO (what I think you're asking about). yhlz said: i'm pretty sure that it doesn't matter what engine you throw in. as long as it's a car that was made after 1975, it will need to pass smog. even if the engine doesn't need to pass smog, you'll have get it verified by the state referee. Unless it's a diesel But yes, I will need to get the BAR to sign off on it being a diesel, and thus not requiring smog. Quote Link to comment Share on other sites More sharing options...
MAG58 Posted July 19, 2009 Share Posted July 19, 2009 Quick question for you CA guys (since I may be moving out there in a year or two) When you do a swap in your post 75 Datsun, does it have to pass smog for the year of the chassis or the year of the engine? Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted July 19, 2009 Share Posted July 19, 2009 MAG58 said: Quick question for you CA guys (since I may be moving out there in a year or two) When you do a swap in your post 75 Datsun, does it have to pass smog for the year of the chassis or the year of the engine? This is the last I will post about CA emissions in this thread. It is moving away from the OP's apparent thought of what the topic should have been. Quote Certification Standards Make sure the engine and emission control configuration on exhaust – controlled vehicles are certified to the year of the vehicle or newer, and to the same or a more stringent new vehicle certification standard. Where I found the above statement. http://www.bar.ca.gov/80_BARResources/07_AutoRepair/Engine_Change_Guidelines.html Quote Link to comment Share on other sites More sharing options...
dhp123166 Posted July 19, 2009 Author Share Posted July 19, 2009 It's cool the whole thing has kind of collapsed anyway and the original topic is moot... Quote Link to comment Share on other sites More sharing options...
