Guest SHARKMAN Posted December 10, 2001 Share Posted December 10, 2001 I want some input from you guys as to what size steering wheel I should use on my car. I plan on using the car for auto-x and show. I won't be using it for a daily driver. I planned on using a 10" --14"flat bottom steering wheel. Car when finished will have coil-overs 275lbs 8" or 10" as recommended by dando's in fremont california. I intend on using 275-17-40 series tires with 10" or 11" rims. I shouldn't have a problem with not enough room for big tires and wheels do to the arizona camel gt fiberglass road race kit. Enough of all that. WHAT THE HECK SIZE STEERING WHEEL DO YOU THINK IS BEST? I hope someone can help shed some light on the subject. Thank's SHARKMAN The same size of springs and the weight of springs will be used at all corners to help create a extreamly well handeling car not intended for a daily driver. Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 10, 2001 Share Posted December 10, 2001 the smaller the better with those big ass tires and no power steering, maybe a little 10" momo or a 12 inch grant wheel, big timer. Quote Link to comment Share on other sites More sharing options...
Guest SHARKMAN Posted December 10, 2001 Share Posted December 10, 2001 MAX SCARAB 327 THANK YOU FOR THAT FAST REPLY.I do have a power steering unit from a 1998 mustang gt and a chevy pump. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 10, 2001 Share Posted December 10, 2001 Quite the opposite, the bigger the better. The bigger the diameter of the steering wheel the more toque you will be able to apply on the steering shaft, and the easier it will be to steer the car, especially on those huhgr front tyres you've got! You don't believe me? Just try turning your steering wheel from the spokes, close to the hub I would recommend a nice 14" momo as they look and feel classy and aren't TOO big Quote Link to comment Share on other sites More sharing options...
Mikelly Posted December 10, 2001 Share Posted December 10, 2001 YUp...Bigger is better...More leaverage. However, with the power steering unit, you should be fine with a 13-14 inch wheel. I'd like info on your power steering... I'm running the same size tires in the rear, and 255-40-17s in front, running 12 inch 250# coil over springs at all four corners. Mike Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 10, 2001 Share Posted December 10, 2001 Yes, a bigger wheel is better for parallel parking and slow driving (maybe even autocrossing if your tires are really wide), but a smaller steering wheel is better once you are moving--there tends to be less (I did not say 'no difference') difference at speed. However, with power steering, the steering wheel size should not be so much of an issue. Davy Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 10, 2001 Share Posted December 10, 2001 thats what i meant mr. davyz, Quote Link to comment Share on other sites More sharing options...
Guest mtj71Z Posted December 11, 2001 Share Posted December 11, 2001 sharkman, are you the guy with the grey z that has teeth on the front bumper??? Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 11, 2001 Share Posted December 11, 2001 whoops, my bad, does that mean a datsun steering wheel is better than the smaller 13-14 grant steering wheels out there, if so than thats nuts, im feeling no handles n the 280. but yes it does make sense, and man i drive two to three different z's a week. hmmm, big steering wheel. Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 11, 2001 Share Posted December 11, 2001 i can understand the big steering wheel working well in parralell parking and small proximity stuff of the sort, but once your moving, isnt a wheel a wheel and the smaller the better then??????? i dont think he got the big tire setup to paralell park with the greatest of ease now. Quote Link to comment Share on other sites More sharing options...
Guest SHARKMAN Posted December 15, 2001 Share Posted December 15, 2001 quote: Originally posted by Mikelly: YUp...Bigger is better...More leaverage. However, with the power steering unit, you should be fine with a 13-14 inch wheel. I'd like info on your power steering... I'm running the same size tires in the rear, and 255-40-17s in front, running 12 inch 250# coil over springs at all four corners. Mike click here Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted December 15, 2001 Share Posted December 15, 2001 The powersteering rack from my 88 BMW 325 looks almost identical to the rack on my Z, only difference being the mounts and hoses. Maybe it would be worth looking into for someone wanting powersteering in their Z. Thure Quote Link to comment Share on other sites More sharing options...
Guest SHARKMAN Posted December 15, 2001 Share Posted December 15, 2001 I just wanted to say the original up grade was written saying it would bolt right in. The story now has been updated to included the steering shaft as well. And the amount of work involved doesn't sound all that bad. I'm not saying it isn't a lot of work,but I beleave the end result would be worth it. Quote Link to comment Share on other sites More sharing options...
Guest SHARKMAN Posted December 15, 2001 Share Posted December 15, 2001 This message is for mtj71z. I do not own the car you mentioned. But I have seen it and It did remind me of a shark. But my car is a 1977 280z with the arizona z camel gt road race kit. Quote Link to comment Share on other sites More sharing options...
