need advice and direction
So I finally made the big plunge and got my turbo motor and t-5.
The car is a 77 and I would like to put the entire drive line into it. Im pretty sure I have a good idea as to what parts will be needed and what will need fabricated. But if I missed something please point it out to me.
Parts list
l28et
megasquirt
diy harness
dizzy
hei distributor
fmic
intercooler plumbing
all turbo sensors
turbo t-5 clutch
turbo t-5 flywheel
t-5 transmission
t-5 transm mount
t-5 drive shaft
Before I start the swap I just want to make sure I have everything their. Im really still unsure about the transmission stuff. So far I have gathered that I will need the trans mount, drive shaft and diff flange off a turbo car. But if I remember correctly You can grab a r200 long nose out of a 88 300zx n/a and that will bolt in with no further modifications and I am assuming that would have the appropriate flange for the t-5 drive shaft.
Wow!!
Sounds like your car will be a screamer. :D I have never done a swap like that before...but to make some things easier I would take measurements of your existing drive-line/rear-end combo then put the new stuff you have together in a mock up and measure that. You can then get the measurements of the long nose R200 and add that in to the equation.
As for the flange to drive shaft? I would never assume they are the same, find picture of the flange and compare with your T-5 stuff. The best case scenario is to find someone with an R200 that will let you mock it up.
