JessZ Posted July 30, 2009 Share Posted July 30, 2009 My buddy recently picked up an automatic '77 280z for $2000. I've been into Z's for years now and this is the best deal I've seen. The body and interior are nearly perfect and the engine ran flawless from Santa Barbara, Ca to Austin, Tx and back. Anyway, all this dude wants, against my advice that is, is to have this Z burn rubber; he's the showboat type. Now I've done the l28et into my 240z swap, and of course it will spin the tires, it's got a standard tranny. My question here is, keep in mind all this mug wants to do is burn rubber from a stop, is the l28et going to cut it for this guy, or should work on doing the Chevy/350 hydromatic for off the line, tire burning torque? I prefer to do the turbo swap because I have the know how, however it just does not seem like it has the grunt for the heavier '77 body to produce smoke. And we're not interested in a serious turbo swap, it'd be more of a stock with no more than 11-15psi. Does anyone here have a turbo, auto Z that'll roast the tires without powerbraking? Quote Link to comment Share on other sites More sharing options...
JSM Posted July 30, 2009 Share Posted July 30, 2009 V8 swap for torque an LSD would help also. Quote Link to comment Share on other sites More sharing options...
JessZ Posted July 30, 2009 Author Share Posted July 30, 2009 That's kind of my feeling too. Alright, thanks enough. Now after a v8 swap I'll feel like a Hybridz pro! Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted July 30, 2009 Share Posted July 30, 2009 Put a 4.11 rear end in it. It will burn the tires then. Quote Link to comment Share on other sites More sharing options...
evan1242 Posted July 31, 2009 Share Posted July 31, 2009 pop in a L28et, and a t-5 manual tranny and there will be no problem spinning the tires. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted August 3, 2009 Share Posted August 3, 2009 Tell him to run an electric motor. They have LOTS of torque. Quote Link to comment Share on other sites More sharing options...
Challenger Posted August 3, 2009 Share Posted August 3, 2009 I dont even see the need for a swap. If its in as good of shape as I think the engine must be pretty close to its original power. As Jeff mentioned get a new set of low gears and youd be set. If he doesnt want one tire fires, look into an LSD. Zs are good at burning rubber stock. Quote Link to comment Share on other sites More sharing options...
ozconnection Posted August 4, 2009 Share Posted August 4, 2009 jeffer949 said: Put a 4.11 rear end in it. It will burn the tires then. Dunno 'bout this one. Think about an ordinary farm tractor. Super low gearing, should make the wheels spin easily.....nope, it doesn't. Why? You need revs and power to effectively spin the hoops, something the stock tractor engine lacks. Torque multiplication by gearing isn't the answer IMO. Quote Link to comment Share on other sites More sharing options...
woldson Posted August 4, 2009 Share Posted August 4, 2009 My 83 na will smoke them quite well. Get a lighten fly wheel, or lighten the stocker. I did this and smoking the tires is much much easier. Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted August 4, 2009 Share Posted August 4, 2009 ozconnection said: Dunno 'bout this one. Think about an ordinary farm tractor. Super low gearing, should make the wheels spin easily.....nope, it doesn't. Why? You need revs and power to effectively spin the hoops, something the stock tractor engine lacks. Torque multiplication by gearing isn't the answer IMO. well, more like you need some way of holding the thing in place to get it to burn. Also, big tires=higher gearing tractors tend to have large tires, which are harder to burn than smaller tires. a stock Z burns rubber pretty damn well actually. Drop the clutch at 4 grand and if I had a line lock I'd have a pretty smokey burnout. No LSD but it roasts them both pretty evenly when it peels out. Quote Link to comment Share on other sites More sharing options...
