LS2 / LS7 Clutch/flywheel weights
After researching LS clutches I decided on a GM LS7 pressure plate and disc. Thought I should do business with a company I own. Since this clutch won't fit my '05 GTO flywheel it gave me an excuse to buy an aluminum Fidanza unit, '05 Corvette application.
Using a digital bathroom scale I found the stock LS2 pressure plate weighs about 21 lbs.(9.5 kilos), and the flywheel 24 lbs.(10.9) for a total of 45 (20.4)
The LS7 pressure plate is 3 lbs. heavier at 24 lbs., but the Fidanza is a skinny 13 lbs.(5.9) which, together at 37 lbs.(16.8), save 8 lbs.(3.6) from stock.
Net result: Quicker revs, less weight, lighter wallet.
Steve
Stock GTO LS2
LS7/Fidanza
MoNkEyT88-
I'm in your boat, way out from completion. Mine's on a rotisserie, and will be for a while.
I was just making a funny about how all of us taxpayers now own General Motors.
Good luck on your build, hope you're done before me!
Pete S
Luckily, I got this clutch some time ago.
I hope GM gets their act together soon, I need some other parts too.
