Paulpen Posted August 12, 2009 Share Posted August 12, 2009 Im quite a lurker, reader and searcher but less of a poster but hoping that wont matter : Long story but here goes 18 months ago I did a RB25 (series 1) conversion into my S13. It was my daily at the time and I needed it to work so got someone to do it that was supposedly an expert at it. I did the swap and it didnt start. No power to injectors or coils so I got it running. Skip foward 18 months. Im now breaking my S13 and building a Onevia that the RB is going in. I cleaned all the unwanted wires from the car loom and then get to the engine one. Untape it etc and O.M.F.G its a mess. Ive already sorted out the bodged pins in connectors but have a few questions that I cant really sort without looking at another loom or someone knowing it :bawling: So here is what I know : The R33 harness connects to the dash harness at one point so mine was repinned to fit my dash harness. Currently I have 4 wires in it which ive traced as follows : Yellow/red - splits into two wires and goes to the tacho readout wire in the bay and the ecu Yellow/green - to the ecu Blue/black - Temperature gauge Orange -> grey/red - ecu And thats all I have in that connector as per pic Im guessing this is the R33 version of what im using (but with more wires) strange thing is that I have 3 wires going into this from the engine loom so they go nowhere ! Ive traced them so here goes Black - goes to a purple inlent manifold plug - think its AAC (air con idle up) ? Light blue - Goes to a gray connector with an orange insert, not sure where but possibly front of inlet area. Heres a pic or two as im crap with words Blue/white - splits off into 4 wires after about a foot. These then go to a coil pack plug, what I think is the VVT (first pic below), the oxygen sensor and what I think is the boost solenoid (second pic below). . If you are still reading then thankyou The thing I find strange is that the car seemed to run fine on stock parts but did overfuel a bit and pulled 285ish on standard boost. Help very much welcome Quote Link to comment Share on other sites More sharing options...
Paulpen Posted August 13, 2009 Author Share Posted August 13, 2009 Traced every wire from the ecu connector to its end tonight and here is what ive now got. I used the following guide but not sure if its correct or my loom is missing alot of things :S I made a table of what ive got and where it is and uploaded it here as cant seem to get the table to look correct any other way MEGAUPLOAD - The leading online storage and file delivery service Quote Link to comment Share on other sites More sharing options...
Paulpen Posted August 22, 2009 Author Share Posted August 22, 2009 Well after alot of time and help I think ive got it all done correctly now Just a question about the coil pack loom though - is it meant to have 2 earth bolt connectors ? One goes the the white plug and one comes from inside the tape going to the pack connectors ? Quote Link to comment Share on other sites More sharing options...
Paulpen Posted August 25, 2009 Author Share Posted August 25, 2009 Quote Link to comment Share on other sites More sharing options...
stony Posted August 25, 2009 Share Posted August 25, 2009 I always cringe when i see these threads. I went with an aftermarket ECU for that specific reason. They cost more but in the end you have a cleaner NEW wire harness VS a harness that has been hacked into who knows how many times. Quote Link to comment Share on other sites More sharing options...
Paulpen Posted August 25, 2009 Author Share Posted August 25, 2009 stony said: I always cringe when i see these threads. I went with an aftermarket ECU for that specific reason. They cost more but in the end you have a cleaner NEW wire harness VS a harness that has been hacked into who knows how many times. Surely even with a different ecu (power fc, emanage etc) you still have the same loom there ?! The ecu is only as good as the wires and sensors reporting to it ! Quote Link to comment Share on other sites More sharing options...
stony Posted August 25, 2009 Share Posted August 25, 2009 Well yea i guess your right there. i do have 2 grounds IIRC the small one goes under the ignitor pack and the white one goes under the coil pack base bolt. I dont have access to my motor right now or i would take look and shoot some pics. Do you have the online service manual for the rb? it has some really good pics of the engine and coil harness Quote Link to comment Share on other sites More sharing options...
stony Posted August 25, 2009 Share Posted August 25, 2009 if your interested i have 3 different manuals. PM me your email and i will try and send them to you. they are pretty big. Quote Link to comment Share on other sites More sharing options...
Paulpen Posted August 25, 2009 Author Share Posted August 25, 2009 Pm sent Quote Link to comment Share on other sites More sharing options...
stony Posted August 26, 2009 Share Posted August 26, 2009 Ok i tried to send it but it was too big. either your server or my server wont allow it. here is a link http://cid-d15d93fe41d91127.skydrive.live.com/self.aspx/skyline/gtr|_32|_service|_manual.pdf if that doesn't work the name of the file is gtr_32_service_manual it's a PDF and its all over the internet its 23+meg. if you google the file name you should get a bunch of hits on where to download it from. Quote Link to comment Share on other sites More sharing options...
Paulpen Posted August 26, 2009 Author Share Posted August 26, 2009 Ideal EN56 confirms the coil pack one - just cant find the one from the white connector Quote Link to comment Share on other sites More sharing options...
