rustrocket Posted August 17, 2009 Share Posted August 17, 2009 So i got my engine in my triumph fired up for the first time today...It's an LS2 from a 2005 vette. Engine oil is 0-30w amsoil. Issue is, oil pressure reads low...25 psi at idle (1300 rpm, cold), and only gets up to about 50 when i take the engine to 4 grand. I didnt run it for longer than the video. Is this acceptable oil pressure or should i be looking for problems somewhere? Autometer phantom gauges if that makes any difference. Thanks for the help... Quote Link to comment Share on other sites More sharing options...
Cable Posted August 17, 2009 Share Posted August 17, 2009 I think you are fine, especially with 0w-30 oil in the summer. Quote Link to comment Share on other sites More sharing options...
rsicard Posted August 17, 2009 Share Posted August 17, 2009 rustrocket: Was the engine rebuilt or was the oil pan and pickup disturbed? There is a possibility that the pickup tube inside the pan is not seating properly to the block with an "O" ring. Quote Link to comment Share on other sites More sharing options...
janaka Posted August 17, 2009 Share Posted August 17, 2009 i'd say thats pretty much normal give or take, esp with that oil in there. I'm a tad higher on my ls1 but run 10w30 synth. Quote Link to comment Share on other sites More sharing options...
rustrocket Posted August 18, 2009 Author Share Posted August 18, 2009 Fair enough...Universal consensus is that my numbers are fine, i just expected them to be a little bit higher. I'll report back when i've let the ca run long enough to warm up. The motor was a pullout with 13,000 miles on it. Quote Link to comment Share on other sites More sharing options...
