280zzzz Posted August 18, 2009 Share Posted August 18, 2009 Do most carpet kits have the seating holes pre drilled? We are going to move our seats back and remove the rear seats but We don't want random holes in the carpet Quote Link to comment Share on other sites More sharing options...
langfordchuck Posted August 25, 2009 Share Posted August 25, 2009 Mine, from MSA, doesn't. In any event, it is better to cut a X than to drill out or cut a hole. Quote Link to comment Share on other sites More sharing options...
nismo kid Posted August 26, 2009 Share Posted August 26, 2009 Mine, from MSA, doesn't. In any event, it is better to cut a X than to drill out or cut a hole. +1 I have replaced the carpet in 2 of my z's. I used a utility knife(boxer cutter), the hole poker from a tire plug kit, tape measure, screw drivers, and the mounting hardware for all parts to be installed. I recommend to not even attempt use a drill. All it will do is snag up the carpet and make it look like poo. Its far easier to cut X's where hardware will be going through. I used to tape measure to measure where the holes are. But its not always so easy. This is when the hole poker comes in handy. You can use it to find holes for the hardware. Also do It on a sunny day and let the carpet sit out for a hour or two. This will soften/even the carpet out for far more ease of install. I like the 1 piece units more than the 3 piece ones. That just my opinion Quote Link to comment Share on other sites More sharing options...
