280z Backfires, can't find problem
Have you ever cleaned out you gas tank or replaced you fuel filters? If not you should probably do that soon because my 75's Injectors when I bought the car went out and when I took them off I noticed little metal flakes inside on a small filter in the injectors. All of this was because of a rusty old gas tank which is common for Z's. So you may want to drain your tank to see what the fuel inside is like if it is red or if there are small chunks of metal in it.
Good luck with your project though :D
I replaced the fuel filter when I got the car, (although it has sat alot since then might have gummed up) and I have drained my gas tank once and it was all clear no flakes. I replaced the fuel filter in early - mid months of '08, since then its done tops 600miles lol should probably replace the filter ya?
