Electric Fan
I've read the archives and found that 92 Taurus fans work well but will it fit with a L6 engine? Does anyone have any other suggestion of OE electric fans I could use model and year if possible?
Thanks
you can use any electric fan. the taurus is a good fan because its used in oem apps, usually meaning they were built for daily driving and negative maintenance, these units and units like such last a very long time and can be very reliable. you could always buy one from summit or jegs and get their therm controls or run it off a switch.
Several things to consider. You will want atleast 2000cfm worth of cooling. Typical 16" autozone fans flow 1600cfm, not enough so don't do it. Especially if you are in the south with the heat. Now, you have several choices. Permacool makes a nice fan that flows 2350-2900 depending on whether you run a shroud or not. Your best choice would be a Spal. They make a 16" fan that flows 2320cfm and is very thin, about 3"-3.25"
