sta z Posted August 19, 2009 Share Posted August 19, 2009 this is a stock L28 after a rebuild. does the timing look correct? thanks Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted August 19, 2009 Share Posted August 19, 2009 Looks right to me from where I am sitting. Make sure you are at TDC on the #1 cylinder as well (it looks like you are but confirm it). It looks like you are using the old timing chain or is it a new one? Quote Link to comment Share on other sites More sharing options...
MAG58 Posted August 19, 2009 Share Posted August 19, 2009 Looks right. The little slit on top, where does it line up? If the V notch on the pulley and the little slit on the retainer line up you're in business. Quote Link to comment Share on other sites More sharing options...
bigeZ Posted August 19, 2009 Share Posted August 19, 2009 I just did this last week. Make sure the cam sprocket is in the number one hole on the cam it self. Also look through the sprocket and align the sprockets small groove with the small grove on the head. Also if you havent done so already, replace all bolts that will be torqued. I learned the hard way and had many bolts that hold my front cover break off. Not a fun fix. Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 19, 2009 Share Posted August 19, 2009 Also if you havent done so already, replace all bolts that will be torqued. I learned the hard way and had many bolts that hold my front cover break off. Not a fun fix. maybe you were tightening them to tight ?, never broke a front cover bolt, just don't use a 12 inch bar, I like to use my little 10 / 12 mm ring spanner. or if you have one of those little (6 inch) tension wrenches Nigel Quote Link to comment Share on other sites More sharing options...
sta z Posted August 20, 2009 Author Share Posted August 20, 2009 What if my notch on the cam gear and the head look like this... -v kind of close together but not a perfect dead on. Quote Link to comment Share on other sites More sharing options...
Xnke Posted August 21, 2009 Share Posted August 21, 2009 The notch and dash are not supposed to be dead on perfect, it should be "-V". The chain should be replaced, or the cam sprocket moved to the next hole, when the V and the notch are "V-". Quote Link to comment Share on other sites More sharing options...
sta z Posted August 21, 2009 Author Share Posted August 21, 2009 Thank you very much! Quote Link to comment Share on other sites More sharing options...
