kelltainer Posted September 7, 2009 Share Posted September 7, 2009 Ok So I found a vg30et and ecu, wire harness, tranny, turbo everything I need(at least I think. How hard is this swap? I cant find a good write up on this =(. It seems to me it will fit just fine(just from looking at the two cars engine bays. I cant seem to find a l28et to drop into my car but i found this =D. Thanks! Quote Link to comment Share on other sites More sharing options...
evildky Posted September 17, 2009 Share Posted September 17, 2009 the vg30et lh mount if way at the frotn, and might actually mine up wiht the S130 cromemeber, the rh mount is itn the moddle and will not evne be close, so you'll have to fab a rh mount at the very least, one that fits aroudn the alternator or you'll have to relocate the alternator, it's nto a common swap and if you want to do it be prepared to figure it out and do a bit of fab work, oh and I'm pressty sure the stock VG turbo location is right where your steering shaft goes so you'll also need to add u joints to the steering or relocate the turbo Quote Link to comment Share on other sites More sharing options...
