FiveSeventyZee Posted September 9, 2009 Share Posted September 9, 2009 Ok, so my other thread here was about getting my z running, thanks for all the help guys. Now I can move on to other things, and key engine cooling... So my stock radiator was leaking and I found (by searching the boards) that a Camaro 4 cylinder radiator would work. While at a pick-n-pull I found an entire F-body section so I went on looking and luckily I found a radiator that fits and doesn't appear to have any leaks (not yet at least). I have it all mounted in, except the hoses, and it should be just about ready. Now I'm looking at how to get the air through it. I was thinking I would make a trapezoidal box using the radiator as the front side, dual electric fans on the back and sheet metal closing up the sides. Using these at the end: http://www.summitracing.com/parts/PRM-19128/ so does this sound like an effective cooling method? Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted September 12, 2009 Author Share Posted September 12, 2009 I was looking at a bunch of pictures of engine bays and I can't find any that use the radiator I have. Also, the in and outlets are 1.25 inches while on the engine they are 1.5.... Does this look like the right radiator? It came from a 3rd gen camaro with a v4 engine Quote Link to comment Share on other sites More sharing options...
jhm Posted September 12, 2009 Share Posted September 12, 2009 570- With respect to your differing hose outlet sizes, there are several places that market hose splicing kits -- JTR has a really nice kit. Or, you could fab your own. Or, you could solve your problem like I did with a radiator hose filler like this one from Summit: "http://www.summitracing.com/parts/MOR-63740/" It has the added advantage of enabling you to easily purge your cooling system of any trapped air. Hope this helps. jhm Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted September 13, 2009 Share Posted September 13, 2009 That's the radiator. Grab a Taurus two speed fan and you're good to go. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted September 13, 2009 Share Posted September 13, 2009 you could also but the filler neck that bolts to the intake manifold, they can be switched to point either right or left. Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted September 13, 2009 Author Share Posted September 13, 2009 yeah I think I'm going to get a swivel water neck Quote Link to comment Share on other sites More sharing options...
ekiernan Posted July 5, 2010 Share Posted July 5, 2010 That's the radiator. Grab a Taurus two speed fan and you're good to go. What year(s) Taurus (or Thunderbird) fans work well? Quote Link to comment Share on other sites More sharing options...
hoov100 Posted July 5, 2010 Share Posted July 5, 2010 (edited) What year(s) Taurus (or Thunderbird) fans work well? If you would have spend five minutes on google with the words "taurus fan years" you would have found it in alot let time time it took you to post a reply. (90-95, pretty much anything ford thats FWD with the 3.8 and made in the mid to early 90's.) Edited July 5, 2010 by hoov100 Quote Link to comment Share on other sites More sharing options...
