HICKL Posted September 14, 2009 Share Posted September 14, 2009 I picked up a nos kit (all except the plate), so will be setting my car up for it soon. I would like to spray with my tunnel ram (as it looks really cool) but the added cost and hassle of the dual carb setup has me thinking about simplifying. I have a performer rpm that was on it but was thinking along the lines of a victor jr as they are readily available on the used market. What do you guys think? Will prob run a 150 shot. 383 stroker, sportsman II small chamber heads.... thanks Jeff Quote Link to comment Share on other sites More sharing options...
John Scott Posted September 14, 2009 Share Posted September 14, 2009 pm sent... Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted September 14, 2009 Share Posted September 14, 2009 http://www.summitracing.com/parts/HLY-300-110/ IVE USED THIS INTAKE ON SEVERAL NITROUS ENGINES WITH GOOD RESULTS you can use almost any intake but if youve got the hood clearance a common plenum single plane intake with runners designed for a strait shot at the back of the intake valve, is preferable Quote Link to comment Share on other sites More sharing options...
355Z Posted September 14, 2009 Share Posted September 14, 2009 The usual, Make sure your fuel systems is capable of handling the extra power requirements. Pull a couple of degrees of timing out per 100 hp increase. Colder plugs are your friend, especially with high compression and bottle. I keep a self imposed 150 HP limit unless my pistons are forged. Quote Link to comment Share on other sites More sharing options...
HICKL Posted September 14, 2009 Author Share Posted September 14, 2009 Have forged pistons. Grumpy, I can get my hands on a Victor JR. Would that be equivalent to what you suggested? Looks very similiar. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted September 15, 2009 Share Posted September 15, 2009 the vic jr has smaller ports/runners and a lower runner entrance angle, to the cylinder head port but yes its VAGUELY similar in design, and it will work ok Quote Link to comment Share on other sites More sharing options...
Pyro Posted September 17, 2009 Share Posted September 17, 2009 Since you don't have a plate, you might as well get some foggers and drill and tap into your current intake. I did that on my RPM intake because there was no hood clearance for a plate. Worked great. get a small fuel pump for fuel enrichment. I used a mallory comp70. Another idea is to use a one gallon fuel cell for the n02 fuel enrichment. Then run 114 octane in the foggers. Quote Link to comment Share on other sites More sharing options...
HICKL Posted September 17, 2009 Author Share Posted September 17, 2009 I thought about that and it would be really cool but trying to keep my cost down. I figure by the time I buy 8 nozzles and all the plumbing and solenoids I would need, I would be broke. A fellow Hybrid member is hooking me up with a holley plate so I now have that covered. Quote Link to comment Share on other sites More sharing options...
jt1 Posted September 17, 2009 Share Posted September 17, 2009 The Vic Jr is shorter than the RPM, so that will help with hood clearance. jt Quote Link to comment Share on other sites More sharing options...
Pyro Posted September 18, 2009 Share Posted September 18, 2009 I only used 4 foggers in the intake. With a single plane you could get by with only 2. drill and tap fogger ports about an inch under the carb. you already have the solenoids, right? A plate is easier. Quote Link to comment Share on other sites More sharing options...
HICKL Posted September 18, 2009 Author Share Posted September 18, 2009 you do get that I am running a dual carb tunnel ram right now right? Quote Link to comment Share on other sites More sharing options...
Pyro Posted September 18, 2009 Share Posted September 18, 2009 Use two foggers under each carb. 4 total. Quote Link to comment Share on other sites More sharing options...
