yetterben Posted September 14, 2009 Share Posted September 14, 2009 i have two on my triples that are different from the others. Is this going to be a serious problem until my new ones come? they are .5 inch smaller than the other 4 Quote Link to comment Share on other sites More sharing options...
wondersparrow Posted September 14, 2009 Share Posted September 14, 2009 I am certainly no expert, but personally I would try to make them all the same. Pricey little things from what I recall. Some people have suggested that running 3 short and 3 long would give you the "best of both worlds", but it just seems like a bad idea to have different cylinders having different power outputs. Longer horns from what I understand give you better low-end torque. Shorter ones give better top end power. I have not tested this theory, but it makes sense in my head That being said, I don't see it causing any major issues in the short term. Quote Link to comment Share on other sites More sharing options...
nissan2ner831 Posted September 15, 2009 Share Posted September 15, 2009 I am certainly no expert, but personally I would try to make them all the same. Pricey little things from what I recall. Some people have suggested that running 3 short and 3 long would give you the "best of both worlds", but it just seems like a bad idea to have different cylinders having different power outputs. Longer horns from what I understand give you better low-end torque. Shorter ones give better top end power. I have not tested this theory, but it makes sense in my head That being said, I don't see it causing any major issues in the short term. from what I understand from carb'd Porsche's, this isn't quite correct. If I'm not mistaken, there's actually a point where much longer air horns are better for high rpm applications....I'd have to pull out the book again to find out for sure though. and no, I don't think it should cause any serious problems for a short while. Quote Link to comment Share on other sites More sharing options...
