Got my clock working!
jhm
Well, after owning the car a year, I finally decided to get my clock working (since I was already into the dash chasing dash harness electrical gremlins).
From what I've read, these old clocks on the S30's are amazingly robust -- even after 35 years of hard use. They often freeze up if the car has sat for a long time with a dead battery or the battery disconnected. Most can be coaxed into life again, with a little cleaning up and lubricant. Use a small amount of very light-weight oil on the gears and spinning mechanism. Ensure all parts are able to move freely. And, as I found out, there are two screw pins that provide the mounting platform for the spring/counterweight mechanism (which is basically the motor for the clock). These two screw pins may need to be adjusted to get your clock working....they need to be just tight enough to hold the spring/counterweight mechanism securely, but not so tight that they impede free movement of the mechanism.
Now my clock is working again and keeping perfect time. It's amazing how much the little things in life mean!
jhm
