Looking for a base Map for MSII PCB 3.57
S130Z
After about 2 years of research, It's finally time for me to initiate Project: HCITMHLTDT? (Holly Crap It Took Me How Long To Do This?). I am swapping to a L28eT in about a week and a half and I need a base map to work off of. I recently received my MSII PCB 3.57 in the mail. Since this is my DD from work to home, I need some guidance and don't have as much time as I would like to make my own tune from scratch. (I did run through the stickies to find a map that is close to my setup, but I was unsuccessfull in the hunt.) Here is my setup:
L28ET rebuilt with stock internals. Rebuilt head with minor port work.
AZC 440cc injectors paird with Pallnet fuel rail and Aeromotive FPR
GT30 replica, T3/T04 hybrid SlowBoy Racing tubo.
Bell Engineering Front mount intercooler
3" exhaust from turbo on back
Greddy Type R BOV
Turbonetics Evo wastegate
N42 intake ported to fit 60mm TB
Stock Turbo Dizzy
LC1 wideband
MSII PCB 3.57
I will be running off the wastegate spring at 7psi to start with and slowly work my way up to around 16 psi. Any maps are helpfull!! Also, I am at sea level if that makes a difference to some of you high altitude guys.
Thanks,
Adam Silver
Here is my tune. A lot of it will be pretty far off but it should get you going if you adjust the injector settings and get the trigger angle right for your set up.
Here's what I'm running fyi:
L28ET with 8:1 compression
Factory 280ZXT T3 @ 8PSI
Factory L28ET injectors
Factory L28ET distributor
300ZX coil
MSA Downpipe to 3" exhaust
No intercooler
LC1 Wideband
MegaSquirt II v3.57
camh.msq.zip
  • 3 weeks later...
hey, just wondering if this map will work for my Z:
87' 300zx Turbo
stage 3 clutch/12lbs flywheel
3" intake/exhaust
2.5" piping/24x3x13" intercooler
T-3 8lbs Boost
wideband O2
255 walbro/420cc injecters
bout to add some major cams
i really just want a map for the MS-II that will correct the timing and fuel for the larger injectors and pump, i will have it tuned after the cams/head work/overbore/stroke out/T-4 upgrade, but i would like to be able to have fun with it in the mean time... work on a budget you know! lol
Thanks for playing!
