Clutch Fork Loose? Disengaged?
I recently had to bleed my clutch and realized that my slave cylinder was leaking fluid pretty drastically.
I went to replace the slave cylinder today, and after mounting it on the transmission I found the clutch fork to be completely loose, I can move it in all directions and I feel like I should not be able to do this.
It is to my knowledge that the fork is held onto the release bearing by a clasp or something, is it possible for these parts to become disengaged? If so, is the only way of fixing this to drop the transmission? I cannot see the release bearing through the hole.
there is a spring clip that hold the clutch fork for assembly but once everything is tight it just stays in place unless you take something apart. Only way to fix is drop the tranny. be sure to check the clutch fork fulcrum pin for cracking. they break. cheap to replace if you can find one. while you got it out might want to consider new throwout bearing and rear engine seal.
