p90 head question.....Turbo
akumazeto
It had been posted but I cant find the answer so hear it goes.. My 73 240z has an engine swap..L28 with a P90 head.. If the P90 head is from a turbo model does taht mean I can go EFI with the stock L28et parts? and if so. What do I need. I have SU carbs but before had tripple webs.. I like to go EFI so can anyone tell me what do I need?
Thanks everyone who is going to help me out on this
You probably have the wrong distributor drive shaft. If that's the case, you will need a turbo one and a turbo distributor. From there, everything else will just bolt on to it and you will need to wire it up.
edit: You should get a turbo oil pan too, or tap yours for a drain plug.
he has an N42 block, its an N/A motor someone slapped a P90 on
hey guys I do have a F54 block and a P90 head.how hard and about how much would all the parts cost me to put a turbo on my engine. I have a 18 circuit painless wiring harness in the car. I have a mallory unilite distributor. don't know what this involves to make it happen, but I always wanted to do this. I don't want to swap motors. I like the idea of making my car fast with a datsun motor in it and not a gm 350. thanks.
search. button.
its been covered into oblivion.
