WHP Posted May 18, 2002 Share Posted May 18, 2002 What have you guys found for seatbelt upgrades in 240s? I'm looking for something over the shoulder, retractable for the street. That rear quarter window just doesn't afford a proper view when you can't lean forward. And I hate it when the belts fall out the door when I exit. Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 18, 2002 Share Posted May 18, 2002 I used 280-z belts. Bolted the shoulder retractor to where the stock shoulder belt mounted. Where in NC are you? I'm near Charlotte. Mark Quote Link to comment Share on other sites More sharing options...
WHP Posted May 19, 2002 Author Share Posted May 19, 2002 I'm 30 min NW of Mount Airy. Do the 280 belts stay "loose" then lock with inertia? I hate the kind that every time it takes up a notch it stays there. Quote Link to comment Share on other sites More sharing options...
WHP Posted May 19, 2002 Author Share Posted May 19, 2002 Mark, I'm 2 hours from Charlotte.I have a daughter that lives there. Do you have a V8 Z car? Will Piatt Quote Link to comment Share on other sites More sharing options...
zgeezer Posted May 26, 2002 Share Posted May 26, 2002 Later model 280Z's (I think 77 or so and not 280zx) have three point retractable seat belts that have two separate retractors per side. The shoulder harness is achored off the top of each rear strut housing (a nice plastic cover too) and also in a retractor bolted into a cavity and sill rail. I've put these into my series I 240. I had to fabricate and weld a plate to cover the rear shock towers and to cut out the floor behind each seat to install the "cavities). Long explanation, but find a late 280z and look. All will become clear. Quote Link to comment Share on other sites More sharing options...
