ModernS30 Posted December 28, 2009 Share Posted December 28, 2009 2,500 for a dash swap??. I got my crack free dash for 30bux. Spent a few hours trimming and fitting and BAM it's in there like swim wear. Got the center console fitted it and screwed it down. I changed it back to stock because i couldn't find a black one that was crack free so until then i'm keeping it stock. Mabey when my 7mgte or 396 goes in i will find one and do it again. So how did you mount it? no way it just bolted right up. Quote Link to comment Share on other sites More sharing options...
CArFAn Posted December 28, 2009 Share Posted December 28, 2009 Had it mounted for a little while i used thin pieces of aluminum flat material that i fiberglass to the under side of the dash to where the orginal z mounts were. It was pretty solid, but i took it out because it wasnt black and i needed the correct center console. If i find a mint black one i will do it again, but i have to find the rhd console first. Quote Link to comment Share on other sites More sharing options...
datsundave Posted December 31, 2009 Share Posted December 31, 2009 I don't if it would work but the heads up display might be cool, if you use the wiring form the s13 might be more work than its worth. Quote Link to comment Share on other sites More sharing options...
