brysonzpassu Posted October 7, 2009 Share Posted October 7, 2009 i i currently have a a 77 datsun with a 408 sbc that is near 500 hp i had i street legal for 2 years i am currently pulling out that power plant to doo list... i need to find a ls1 and tranny sell the 408 and 700r i also have a jtr radiator Quote Link to comment Share on other sites More sharing options...
Blown77Z Posted October 8, 2009 Share Posted October 8, 2009 Why are you replacing the SBC? For the LS1, I bought mine on Ebay from a company called fparts. They are highly respected and reliable for LS style engines. http://stores.shop.ebay.com/Fparts__W0QQ_armrsZ1 Quote Link to comment Share on other sites More sharing options...
Bartman Posted October 8, 2009 Share Posted October 8, 2009 You probably aleady know, but your going to have to go with a completely different mount setup. Are you going to make your own? Quote Link to comment Share on other sites More sharing options...
Cable Posted October 9, 2009 Share Posted October 9, 2009 Why are you replacing the SBC? I imagine he is seeking better mpg and street manners. Both of which are easy to get with LSx power. Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted October 9, 2009 Author Share Posted October 9, 2009 i havent decided yet if i will use a pre made mount or make my own i dont really like the jtr setup .. i would like to go with something a bit more solid .... the curent sbc is a built up 408 it gets 8 miles a gallon and its not verry reliable as a day to day set up there was just too much fussing with it ... what do you think of the lm7 and lq4 as alternative to the ls1 and what year do they start to use the displacement on demand Quote Link to comment Share on other sites More sharing options...
Cable Posted October 9, 2009 Share Posted October 9, 2009 i havent decided yet if i will use a pre made mount or make my own i dont really like the jtr setup .. i would like to go with something a bit more solid .... the curent sbc is a built up 408 it gets 8 miles a gallon and its not verry reliable as a day to day set up there was just too much fussing with it ... what do you think of the lm7 and lq4 as alternative to the ls1 and what year do they start to use the displacement on demand JTR doesn't make a LSx mount kit, JCI does and that is what I am running as are dozens of others. JTR does sell LSx swap headers that are made custom for them by Sanderson. They are designed to work with JCI swap kit. I am also running these. I hear you on the gas mileage part. My last Z had a built big block 454 Chevy and got horrid mileage, but sure was fun! From someone who has run both a 2004 LM7 5.3 and a 2005 LQ4 6.0 I can tell you that both are awesome motors. IMO LS1/LS2/LS3/LS6 motors are way overpriced. I believe DoD came out in 2007 with the truck motors, but I wouldn't mess with the DoD. If mileage is a goal you don't need to worry. There are several here that have reported 30 mpg with their setups and many more I know are getting 25+ mpg. Quote Link to comment Share on other sites More sharing options...
bleakdragonmage Posted October 10, 2009 Share Posted October 10, 2009 Couldn't he use a set of mount adapters that adapt the SBC to LSx engines? I would imagine since he has a SBC in his car already he could use them. I was kinda planning to go this route eventually because i can pick up a LQ9 fairly cheap b/c my dad has a couple at his wrecking yard. Quote Link to comment Share on other sites More sharing options...
Cable Posted October 10, 2009 Share Posted October 10, 2009 Couldn't he use a set of mount adapters that adapt the SBC to LSx engines? I would imagine since he has a SBC in his car already he could use them. I was kinda planning to go this route eventually because i can pick up a LQ9 fairly cheap b/c my dad has a couple at his wrecking yard. Tried that. It would make headers a pain. Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted October 10, 2009 Author Share Posted October 10, 2009 i looked at those and than would make 3 pices of steeel for the mount . that seems a bit scary what about puting the lm7 with a 700r i know you need to change the valve body becaus of the tv cable and you need a adaptor for the fly wheel i callled summit asking them and they didnt know what i was talking about Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted October 13, 2009 Author Share Posted October 13, 2009 what about the truck oil pan any of you have a pic of the clearence using the jci mounts Quote Link to comment Share on other sites More sharing options...
Cable Posted October 13, 2009 Share Posted October 13, 2009 what about the truck oil pan any of you have a pic of the clearence using the jci mounts Nope, the truck pan will not work without lifting the car 8"+. Your only oil pan options (that I am aware of) are LS1 '98-'02 F-Body or '05-'07 Corvette LS2 (only the Corvette pan, not the TBSS, GTO, CTS-V, etc). Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted October 13, 2009 Author Share Posted October 13, 2009 i was looking at the specs on the hummer oil pan it is only 6 in tall how far down would that stick out Quote Link to comment Share on other sites More sharing options...
Filmjay Posted October 13, 2009 Share Posted October 13, 2009 LQ4 is an iron block 6.0L (no sleeves)....so with the available Lunati kit, you can stroke it to a 427. Some LS2 heads...and you're smokin'...probably even putting down more than your SBC, and with better mileage. Then again, if it's 20mpg you're after....nvm. Quote Link to comment Share on other sites More sharing options...
Cable Posted October 13, 2009 Share Posted October 13, 2009 i was looking at the specs on the hummer oil pan it is only 6 in tall how far down would that stick out Even if that is true, I'd think a '98-'02 F-Body oil pan would be cheaper and easier to find. LQ4 is an iron block 6.0L (no sleeves)....so with the available Lunati kit, you can stroke it to a 427. Some LS2 heads...and you're smokin'...probably even putting down more than your SBC, and with better mileage. Then again, if it's 20mpg you're after....nvm. In order to get 427 cubes with a 6.0 block you'll need a 4.25" stroker crank. That sounds nice on paper, but in the real world its another story. The problem with even the 4.00" stroker kits is the piston skirts are very short and they tend to rock in the bores and the make matters worse the the cylinder bore skirts on iron LS (4.8/5.3/6.0) blocks aren't as long/deep as the aluminum versions so the pistons leave the bores more on bottom dead center. Both of these issues will ruin a set of pistons over time. I can only imagine the length of time that a 4.25" stroker piston will last..... Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted October 15, 2009 Author Share Posted October 15, 2009 so next week i am driving to la and then up the coast to seattle i would love the chance to see a converted z dose any won live out there that wouldent mind a visitor checking out there z Quote Link to comment Share on other sites More sharing options...
Cable Posted October 15, 2009 Share Posted October 15, 2009 so next week i am driving to la and then up the coast to seattle i would love the chance to see a converted z dose any won live out there that wouldent mind a visitor checking out there z I live 2 hours North of Los Angeles just off the 99. There are two of us LSx powered S30 Z's here in Bakersfield too. Quote Link to comment Share on other sites More sharing options...
bleakdragonmage Posted October 15, 2009 Share Posted October 15, 2009 I live in Whittier. Its on the La/Orange county Boarder Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted October 16, 2009 Author Share Posted October 16, 2009 wel i am attending a event in orange for halloween so the monday after would it be cool to meet up with ya in bakersfield and check out your z cars my e mail is brysonswing@gmail.com how dose monday the 2 sound Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted October 19, 2009 Author Share Posted October 19, 2009 ok so what kind of power can i get out of the lm7 like if i change the cam and intake i have heard you can get a lot of power from the lq4 i am just wondering witch one i should i start with and will i be happy with the lm7. Quote Link to comment Share on other sites More sharing options...
Cable Posted October 19, 2009 Share Posted October 19, 2009 ok so what kind of power can i get out of the lm7 like if i change the cam and intake i have heard you can get a lot of power from the lq4 i am just wondering witch one i should i start with and will i be happy with the lm7. For the price difference, I am sure you'll be happy with the LM7 and a mild cam like the Lunati Voodoo 60510. Quote Link to comment Share on other sites More sharing options...
