z ya Posted July 4, 2002 Share Posted July 4, 2002 Anyone running a 700r4 with a Holley 4150 Double pumper? Is there to much throw in the linkage for the 700's tv cable???? Quote Link to comment Share on other sites More sharing options...
John Scott Posted July 4, 2002 Share Posted July 4, 2002 Used to have a 600 dblpmpr w/ 700r4. As long as the placement of the hole is the right distance from center on the bellcrank, and tv adjusted correctly it worked perfectly for 5 years. Don't have all the measurements anymore. John Quote Link to comment Share on other sites More sharing options...
JohnG Posted July 8, 2002 Share Posted July 8, 2002 Yes. Had the same problem, due to incorrect geometry of the stock Holley carb linkage. I solved it with a Sonnax corrector plate that bolts onto your linkage and gives the correct geometry for the TV cable. Go to www.sonnax.com, and use the search function to find part # AS2-02K "Throttle Valve Corrector for Holley Carb". Cost around $30 delivered. Quote Link to comment Share on other sites More sharing options...
