T-5 Shifter linkage...
Delasangre4231
I don't know if that will solve your problem, but yes you can pull out the shifter easily. Its just 4 bolts on the shift plate to pull out the assembly. If your trans is indeed a T5 you can use any shifter or short shifter from the T5 '80-90's Mustangs. I have a Pro 5.0 shifter on my T5 out of an '83 ZX Turbo.
shifter09.jpg - picture of T5 shifters.
http://www.az-zbum.com/information.transmission.shtml - Z31 Transmission Info
Need to drop the transmission. You can't remove the top cover of a T5 through the shifter hole in the console and floor pan. It probably is just a roll pin betwen the rod and fork, but "while I'm at it" syndrome will kick in and you might as well rebuild (bearings, synchros, seals) the transmission while it is out of the car.
