Delasangre4231 Posted October 25, 2009 Share Posted October 25, 2009 I can grab the front edge of the driver window and move it up and down about 1/4-1/2 inch, is this a loose bolt in the window regulator system? Easy fix? Quote Link to comment Share on other sites More sharing options...
Careless Posted October 26, 2009 Share Posted October 26, 2009 easiest way would be to take the door panel off slightly, and peel back any plastic vapor barrier and move the window as you do to test the movement.. you'll see whether it's a plastic clip of some sort or a bracket/bolt that needs attention. get a panel clip puller at napa for 1 dollar. it's delicate surface friendly and won't marr anything. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted October 26, 2009 Share Posted October 26, 2009 Just checked my 85 and my 86. unless the window is hard up there is about that much slop. If the window is down part way you can pick it up about 1/2 inch. Quote Link to comment Share on other sites More sharing options...
Delasangre4231 Posted October 26, 2009 Author Share Posted October 26, 2009 Well it shouldn't be there... If I dont pull it up that last half inch water drips through... Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted October 27, 2009 Share Posted October 27, 2009 then I 'd say you need to adjust something. Mine don't leak. when the door is open and the window is all the way up there is no slop - everything is tight. Quote Link to comment Share on other sites More sharing options...
