texasz Posted November 9, 2009 Share Posted November 9, 2009 Ok, I'm searching for a source for my last major component for my engine rebuild and need to know where I can get a good set of 6 KA24E pistons from at a good price. Per Zhome.com the part number on this is 12101-40F10. Quote Link to comment Share on other sites More sharing options...
Guest eric_503 Posted November 10, 2009 Share Posted November 10, 2009 Theres rock auto,but it appears that this is $102 per piston,unless im slow and its the set but I doubt it. http://www.rockauto.com/catalog/x,carcode,1208911,parttype,5620 how far that gets you ahead,im not sure,maybe sets are more expencive but i highly doubt it? Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted November 10, 2009 Share Posted November 10, 2009 KA24E, not KA24DE? ok, C/clip or P/Pin type? set of 4, STD size, Press fit piston pin type, no rings, $97.22 NZD, set rings, STD size $64.49 NZD. set of 4, STD, circlip piston pin retainer type is POA, but .50 over (MM, not half inch) is 95.40 NZ rings the same. That $102 quoted from rock auto could well be for a set. There would be a heck of a lot more demand in the US with 300 mil ppl than here in NZ with 4 mil ppl, so economies of scale + exchange rate could make those cheaper than the same thing here. Edit: buy 3 sets, split one box of 4 and sell a set of 6 on here at cost to other stroker builders, probably easier if you can afford it than persuading a retail chain to split a box of 4 in the first place. Quote Link to comment Share on other sites More sharing options...
giorgio61 Posted November 10, 2009 Share Posted November 10, 2009 Try Bruce at partsdinosaur.com, good prices too. Quote Link to comment Share on other sites More sharing options...
texasz Posted November 10, 2009 Author Share Posted November 10, 2009 KA24E, not KA24DE? ok, C/clip or P/Pin type? set of 4, STD size, Press fit piston pin type, no rings, $97.22 NZD, set rings, STD size $64.49 NZD. set of 4, STD, circlip piston pin retainer type is POA, but .50 over (MM, not half inch) is 95.40 NZ rings the same. That $102 quoted from rock auto could well be for a set. There would be a heck of a lot more demand in the US with 300 mil ppl than here in NZ with 4 mil ppl, so economies of scale + exchange rate could make those cheaper than the same thing here. Edit: buy 3 sets, split one box of 4 and sell a set of 6 on here at cost to other stroker builders, probably easier if you can afford it than persuading a retail chain to split a box of 4 in the first place. Yes, the KA24E is a flat (nealry) top whereas the KA24DE is dished. Pins, is one better than the other? On the Rock Auto that price is per piston as well as the cost of rings on top of that! They are way expensive....I've seen sets of 4 for far less. Catch of course is that I do not need 4, I need 6. I have considered buying three sets of 4 and splitting one like you suggested. Would prefer not to go that route though unless I have to. Quote Link to comment Share on other sites More sharing options...
Ereschkigal Posted November 12, 2017 Share Posted November 12, 2017 (edited) I know the thread is old but it's a current problem. Many of the old Nissan Parts # aren't available. I found a few numbers but I am missing details for the parts: zHome FAQ: 12101-40F10 flat tops zcar.com forum: One guy ordered 12101-40F10 and got 12010-40F10 "They are 89mm and are flat tops. Is this a misprint or am i screwed. " Available Pistons: https://www.nissanpartsdeal.com/parts-list/1989-nissan-240sx/piston-crankshaft-flywheel.html?PNC=12010 12010-40F10 STD GRADE 1 07/1988-10/1988 12010-30R12 STD GRADE 3 10/1988-07/1990 Replaced by: A2010-30R12 Which one is correct as for 89 mm and flat tops or <6cc ? Edited November 12, 2017 by Ereschkigal Quote Link to comment Share on other sites More sharing options...
