MacDrizzle Posted November 12, 2009 Share Posted November 12, 2009 I am swapping an L24 into my 240SX. I have heard many things about S13s and L series engines and have seen a few L28 in 240sx's. I need to know will the L series bellhousing bolt to my existing KA 5spd?. I have heard of people swapping in an RB crossmember and using Z car mounts. Is this legit? What tranny crossmember mods need to be done to use the existing shifter location? I see that the firewall may have to be massaged for clearance. I am not concerned about any fabrication that may have to be done. I am skilled in that area. I am planning to bore the 24 block to use 28 flatop pistons. The rotating assembly will be forged except for the crank. I will have a decent street/strip style cam. Will an L28 head bolt to a 24, if so I will use the L28 head that I have. I'm going to build a 4 barrell intake manifold with short runners. Will a 390cfm carb suffice or can I get away with a 500cfm unit? As for the header i was thinking about buying a 240z header and modifying it to work with my chassis, other wise i will hand build one with equal length primaries. I would appreciate feedback from experienced builders, and or people who can direct me to someone who has done this swap. Please be respectfull, i wont be talked out of this. Im doing this for fun and I don't really care how much power I make. Thanks Mac Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted November 12, 2009 Share Posted November 12, 2009 Most of your questions can be answered by using the search feature. But, off the top of my head... L series (six cylinder) heads are all swappable. E88, E31, P90, P90a...if it's for a L24/L26/L28, you can put it on any of them. 390 is probably more than enough for a little L24. the KA 5spd will not bolt to the L (AFAIK). If you want a five speed, you should start looking for a L specific one (they're pretty cheap though, so it won't be hard). as for overboring an L24, why not just use an L28 in the first place? or if you're really set on using the stroke of a L24, just swap a L24 crank into a L28 block. As for the questions re S13s...probably going to be better off asking on a different forum. People here are generally going the other way with engines. Quote Link to comment Share on other sites More sharing options...
Daeron Posted November 13, 2009 Share Posted November 13, 2009 The KA transmission is a direct line descendant of the L6 transmission. Same holds true for each cars' respective automatic transmissions. Incidentally, the auto box is also the same box as the 4EAT gearbox that Subaru has used in almost all of its cars for the last 20 years. The KA fivespeed can be adapted onto the L28 by taking the bellhousing of the L-series gearbox and machining it for a larger input shaft bearing, and then installing that bellhousing onto your KA gearbox. I may be overly abbreviating the process, but in essence, it is that simple. Nosing around should turn up many threads regarding this conversion; I suggest you go to the drivetrain subforum, I think it is a sticky there. Quote Link to comment Share on other sites More sharing options...
MacDrizzle Posted November 13, 2009 Author Share Posted November 13, 2009 Thanks guys for the good info!!!! Quote Link to comment Share on other sites More sharing options...
(goldfish) Posted November 13, 2009 Share Posted November 13, 2009 I forget which site, here or zcar, but pallent did some documentation when he did the swap. Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted November 13, 2009 Share Posted November 13, 2009 (goldfish) said: I forget which site, here or zcar, but pallent did some documentation when he did the swap. http://forums.nicoclub.com/zerothread/458190-l28-s13 http://forums.hybridz.org/showthread.php?t=144075&highlight=240sx+l28et http://forums.hybridz.org/showthread.php?t=109632 http://forums.hybridz.org/showthread.php?t=130687&highlight=s13+hybrid Quote Link to comment Share on other sites More sharing options...
pzofsak Posted November 16, 2009 Share Posted November 16, 2009 One more thing to consider, if it applies to your state, is that you will most likely have to meet emissions standards for car's year model. That is the way it is here in Texas. Quote Link to comment Share on other sites More sharing options...
zuum Posted November 18, 2009 Share Posted November 18, 2009 The L24 makes LESS hp and tq than the KA24DE... and costs more to make that power. Yes it will bolt on... the oil pan will be tilted 15degrees the wrong way though. http://forums.hybridz.org/showthread.php?t=153150 Quote Link to comment Share on other sites More sharing options...
