IdahoKidd Posted November 20, 2009 Share Posted November 20, 2009 I have the engine out of my 83 turbo donor car but now I have to get rid of the carcus. I have the fuel injection harness out but the wire to the knock sensor is in a different loom. Do I need to pull that loom out as well or do I run a dedicated wire for the knock sensor and if so, where does it connect to on to on the other end? (this is all going into my 77 280) Before this goes to the crusher, what else do I need to pull for engine management? Once it is gone, it is gone. thanks, Leonard Quote Link to comment Share on other sites More sharing options...
stravi757 Posted November 21, 2009 Share Posted November 21, 2009 Did you get the Ecu, AFM, the thingy to make the tach work, maybe the cv's, the coil and ignitor, fuel pump relay...? Just making sure before you toss it. Quote Link to comment Share on other sites More sharing options...
IdahoKidd Posted November 21, 2009 Author Share Posted November 21, 2009 Got everything but the axles so far. Not sure I'll get them out but probably wouldn't hurt. Quote Link to comment Share on other sites More sharing options...
softopz Posted November 22, 2009 Share Posted November 22, 2009 dont just get the axles get the companian flanges that the axles bolt to ! swap it to your 280z while your at it take the diff too and disk brakes. Quote Link to comment Share on other sites More sharing options...
