240SX TPS on L series TB???
2eighTZ4me
I pulled the TPS off my 240SX TB - the half moon bar that drives the TPS appears no different from the one on a regular L series TB. I already have a larger TB with a TPS on the L series now. I'm sure there's a reason why I can't just take the TPS off the 240SX TB (which has the 3 wire pigtail needed to interface with MS) and put it on my existing 60mm TB??
I'm not sure if it will help you since you're not using a Z throttle body, but I was able to use a 240SX TPS by using two large washers with the bolts that were used on the Z TPS. I was able to set it so the washers sit over the "wings" coming off of the 240SX TPS, and it is able to hold the TPS down. Hope that makes sense!
