l28 help
letoburito23
I blew the head gasket a few months ago and have had the head resurfaced and rebuilt i just got the whole engine back together and have been working on getting it running again i finally got it started yesterday and its running rough it stumbles real bad when revving the engine any opinions or help will be appreciated im new to these cars and need some s30 wisdom.
Your cam timing may be off. Did you make sure the cam gear was in the correct place when you got it back from the machine shop. I know when I got mine back I had to double check it, and sure enough it was in a different spot. Also, did you make sure the timing chain did not fall into the front cover while you had the head off? And did you make sure to mark what link on the chain went on a corrisponding tooth before you took it off? If you did not do any of these, you will most likly need to putt the front cover and redo your timing.
Yeah when i got the head back from the shop the cam gear was off and i put it on before i put the front cover on cause i realized that without taking that off i couldnt get the chain tensioner or cam gear back on. I followed everything exactly how the haynes/chiltons and the factory repair manual says to do but ive tinkered aroud with vacuum lines and its running now any ideas on how to keep broken injector clips in place?
