Gas Tank Leak ...help!
I found this gas leak from the back of tank where the sender unit connects. The connector things are very loose. I think I need to replace it. Do you guys know if they sell the part?
Also, what would be the procedure to replace it. I just had filled up the tank too.
Any advice would be appreciated.
Car is 1972 240z.
Thanks!
I order a new sending unit from The Z Store. Also, ordered the O-Ring and the nut thingy. I might as well see what shape the tank is internally, I'm hoping I can peek in through the hole. If okay, I might as well paint it. If not, go get it refurbished.
The fun never ends.
